Configures the OSPF wait interval for a VLAN or all VLANs.
vlan-name | Specifies a VLAN name. |
all | Specifies all VLANs. |
retransmit-interval | Specifies the length of time that the router waits before retransmitting an LSA that is not acknowledged. The range is 1–3,600. |
transit-delay | Specifies the length of time it takes to transmit an LSA packet over the interface. The range is 1–3,600 seconds. |
hello-interval | Specifies the interval at which routers send hello packets. The range is 1–65,535 seconds. |
dead-interval | Specifies the interval after which a neighboring router is declared down due to the fact that hello packets are no longer received from the neighbor. The range is 1–2,147,483,647. |
wait-timer-interval | Specifies the interval between the interface coming up and the election of the DR and BDR. Usually equal to the dead timer interval. |
The following command configures the OSPF wait interval on the VLAN accounting:
configure ospf vlan accounting timer 10 15 20 60 60
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
